497 Vistas, 4 Respuestas
Make points or point clouds to solid 3d
Hello guys, iam wondering is there any solution for making point clouds to 3d solid for easier to work. ? Thank you
cuslund
en respuesta a: Anonymous
We supply point clouds so would be handy as well to know what they can actaully be used! I ahve heard people from Laser scanning forum they can make a mesh out of them, but not sure how?
mikeevans6697
AutoCAD Civil 3D will allow a user to make a TIN model with the point cloud data.
Mike
john.vellek
Hi @Anonymous,
AutoCAD is not capable of doing this but AutoCAD Civil 3D can utilize the point data to create this. There is also an open source site (just search on the web) that should be able to help you with this process.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
