- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hatch - weird behaviour
I attached a DXF with a hatch with a weird behavior. If it's selected, it doesn't have a closed boundary.
Is there any way to fix the existing hatch, other than I draw it again?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sorry, No (based on my limited knowledge).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Absolutely normal (not good, but normal).
1 Hatch without associated bounfary objects
also
2 Hatch created by using open shapes
Not really good, but nothing "wiered".
Test it: use LINE and draw a big "V", now create a hatch by using the SELECTION method, not the pick- method.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>">> Is there any way to fix the existing hatch, other than I draw it again?"
You can re-create the boundary object
HATCHEDIT
and the use JOIN
and set the CLOSED property to your polylines
Thats "near to" the solution you asked for.
Most more important: WHY the xxxx is your file saved as R14 Format???
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"near to" may or may not be, the missing segment could be just one line, it could also be an arc or multiple segments that are missing now, so we don't know how the open part was connected.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"so we don't know how the open part was connected"
It wasn't connected or better: It wasn't important for the hatch.
"LINE or ARC" This is known
Ok, perhaps it was a polyline or a circle, but the important part for the hatch
(the part what was part of the boundary) you can re-create by this way.
sample attached
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you all.
One more thing. For an open polyline it is possible to set Closed=Yes to close it.
Is there anything similar for hatch?
