Kent1Cooper
en respuesta a: pendean
@pendean wrote:
.... you can apply manual overrides to any and all objects ... using PROPERTIES command.
I recommend that you use the CHPROP command instead, because in it, as long as it's one defined in AutoCAD's linetype definition file, it is not necessary for the linetype you want to assign to be already loaded in the drawing, as it is if you want to assign it in the Properties palette.
Kent Cooper, AIA
