795 Vistas, 3 Respuestas
Plotting to EPS
Hi, I was wondering if someone could help me sort out this problem. I installed and re-installed (following typically recommended steps : Add a plotter>my computer>postscript>plot to file ) the postscript plotters. When I go into my print command, and select any of the postscript plotters, I can preview them. They save with a .eps extension. However, when I try placing them in Illustrator CS5.1 or Photoshop, they are blank. What am I doing wrong here ?
imadHabash
en respuesta a: Anonymous
Turn off plot transparency..
Good Luck..
Imad Habash
en respuesta a: imadHabash
That worked !! Thank you so much !! So, what happens if I want to plot hatches with reduced opacity ?
imadHabash
I think this is a real problem that fellows in Autodesk must worry about.
Imad Habash
