>> I have to close out of autocad and get back in to make it work.
Am I correct that when you start command _PAGESETUP AutoCAD stops responding .. until you press <ESC> ... does this bring AutoCAD/Civil 3D back to live?
If yes (which I assume) your pagesetup window is outside the display area of your current monitors.
Try this:
  • start the command
  • press <ALT><SPACE> ... this brings a popup menu
  • use keyboard cursor down to "Move" in this popup
  • use <ENTER> to start move
  • use keyboard cursor <Left> or <Right> to move the missing dialog
  • when you see the dialog you can continue with the mouse ... show the new location and left click to set it.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
