pendean
en respuesta a: peells
You need to be using the exact variant of AutoCAD that created those objects: sorry.
Workaround? Ask the file creator to "export to autocad" that file, you'll get a dumbed down version for your exclusive use (they can't use it if you send it back).
If you are on subscription (not maintenance) with AutoCAd you are free to download and install AutoCADMEP and use, its a perk you are paying for https://www.imaginit.com/software/autodesk-products/autocad/mep-toolset
Still on maintenance? Know now that Autodesk is killing it off in a little over a year so you'll need to figure it all out eventually https://forums.autodesk.com/t5/subscription-changes/bd-p/6073
HTH
