OwenWhitehouse_ASTI
en respuesta a: peells
I'm assuming you have the Fabrication CADmep Object Enablers installed so you can see those proxies, but you probably will not be able to move them without having the actual application installed. You could convert those objects to regular AutoCAD graphics using EXPORTTOAUTOCAD, but as you said, you require the properties to be intact, and the conversion would strip them of that extra metadata.
Owen Whitehouse
