853 Vistas, 5 Respuestas
In paper space not working hatch and wipe out . showing the model space opject
Am facing an issue in paper space layout. I cant put any hatch and wipe out comment in paper space layouts. its showing transparent and visible in model space objects. please need solution for this.
vinodkl
en respuesta a: Anonymous
Try to purge and audit the drawing. If this does't help please post the file, so that we can help you out
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
en respuesta a: vinodkl
Hi vinod,
I just do the purge and audit. when I audit its a message show an invalid
registered application name found then system suddenly hang.
vinodkl
Open a blank DWG and run the RECOVER command. Select the problematic file. Now AutoCAD will attempt to recover the file and open it.
Alfred.NESWADBA
please start _PAGESETUP or _PLOT and make sure the "Plot paperspace last" is activated ... better?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Thank you Alfred. Now its okie...
