Kent1Cooper
en respuesta a: Anonymous
Apparently the 98.00 Dimension and those to its right with smaller text content are of different Styles  [I assume because of the different colors of the dimension and extension lines].  If that's right, you don't show the Dimension Style dialog boxes for both.  Do they use the same text Style?  If not, does one of those Styles have a fixed height?  [If that's the issue, the text height slot in the dialog box should be greyed out.]  Are either of them Annotative  Dimension Styles?
Kent Cooper, AIA
