Alfred.NESWADBA
en respuesta a: Anonymous
in the screenshot we see the effect, but we don't know to which image or objects we look at.
First at all ... is this a screenshot of the render window or to the AutoCAD graphic window with visual style "Realistic".
When you assign a material with texture you also need to assign the texture mapping coordinates .. have you done that? You can do that with command _MATERIALMAP and option "copY mapping to" to transfer mapping coordinates from an object that looks correct to another object.
Also interesting ... which version of AutoCAD are you using?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
