02-17-2020
09:47 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-17-2020
09:47 PM
The problem is due to the objects are at elevation.
To fix this use the command "FLATTEN" and select the object and then press enter=> remove hidden lines" <NO>.(it would take little longer time than expected)
Then use the command "PLAN" and then select "Current UCS"
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
