- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, I would like to ask for solution, since I'm very new to autocad macros
I have drawings set from other party that i have to revise, unfortunately they don't use xref and only using blocks,
and they split their drawings to multiple files, so i have to use adcenter to redefine block one by one in each drawings
I search the forum and found solution for macros as below:
-INSERT
title=
Y
(COMMAND \e "RESUME")
but unfortunately macro above only works for drawing name that does not contain space
if, let say the drawing name is title 01, it would not work
i try to use "title 01" between the filename:
-INSERT
"title 01"=
Y
it will say:
Command: -INSERT
Enter block name or [?]: "TITLE 01"=
Warning: If you are trying to insert the file: "TITLE 01"
it must be inserted using the <block>=<filename> syntax.
Command: Y
Unknown command "Y". Press F1 for help.
Is there a solution for my problem above? would very much appreciated for the help ![]()
thank you
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
please do not start multiple threads with the same question (just added the space in filename issue).
You have already a thread and active discussion >>>there<<<, please continue in that thread.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am running 2020 with arch toolsets and found that when I used the quotes for the long file name it worked but did not work for a "block name". It reads back the block as test 1" for why I have now clue. I personally don't like to use file names or blocks or pretty much anything with spaces within Autocad. That said If you rename the block then the a script will work. You should also rename the base.dwg naming if possible.
You could make two scripts. one to rename and then another to do the block update.
;first script renames the block
-RENAME
B
"cir 1"
cir-1
;next script
-insert
;block name=dwg file location and namecir-1=c:\plot\cir-1.dwg
0,0
1
1
ERASE
LAST
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In Scripts, dealing with the strings with spaces will be in this format in order to continue.
(command "insert" "a3(tags)=C:\\Users\\dmmn0800\\Documents\\a3(tags).dwg" "0,0" "1" "1" "0")
in this situation, i replace the block named "A3(tags)" with a new one. Even the file name of the new block has space, (e.g A3 Tags.dwg) the script can read it because it was written in autolisp format.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
technically this works, although need to workaround a bit, but still it get the job done
I just rename the block name to remove the space, and then just use the first script to batch redefine
thanks for all the help
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
