j.palmeL29YX
en respuesta a: Anonymous
@Anonymous wrote:
I have had a line I wanted to add another line to in the same direction.
You can use the Osnap PARallel as shown in >>this video<< .
A first line was drawn in any direction. Now
- start the new line command,
- choose a start point,
- activate the OSNAP PAR(allel),
- hover the cursor to the first line,
- move the cursor until you see the temporary line,
- type the length you need (here  100).
BTW: I'd suggest never to use (to type in) a value which is shown in the property window or after the list command or others, because the shown values have a limited precision.
In some cases you also can use the Osnap Extension. (I'm not sure what you want to draw)
>>Example<<
Jürgen Palme
