Alfred.NESWADBA
en respuesta a: Anonymous
>> every time I click a hatch pattern the autocad freezes or lags
Do you have the property window open? If yes, do you see the same lag when you close the property window before you select the hatch?
Does the same happen in a new drawing with a rectangle hatched (using ANSI31) too?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
