en respuesta a: Alfred.NESWADBA
as I understand , the dimension you see is 5/8 when you open it in Autocad 2020 !?
 because the same file I open in my computer is showing this clip, and when I double click on the dim it goes back to the original dimension.
just to let you know , when you double click on the dim , it goes back to normal and the issue will not show until you republish again
