32037 Vistas, 10 Respuestas
Electrical symbols
Greetings everyone, first post.  I am very new to AutoCAD, approximately 4 weeks in.  I'm attempting to work on an assignment for school work, in which case we need to create a very basic Electrical Legend, using MTEXT.  The problem that I'm running into is locating all of the appropriate electrical symbols.  I've done a decent bit of searching, however most results end up pointing me to products that are not what I am using.  I am using a licensed student version of AutoCAD 2018, and am coming up empty, and becoming extremely frustrated.  Any help from the experts here would be greatly appreciated!  Thank you in advance!
Matt
imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoCAD Forum,
Sorry ... to understand well . are you looking for Electrical symbols or what ?
Imad Habash
en respuesta a: imadHabash
Correct, I am having a very difficult time figuring out how to locate and incorporate electrical symbols into an MTEXT field, unless of course there is an easier way to accomplish it.  For example, if I create an MTEXT field, and click on my Symbols button, it will give me an Electrical Phase symbol, however that is for a single receptacle.  I am attempting to find symbols for items like a duplex/double receptacle, GFCI receptacles, split wired receptacle, 220/440 receptacle, overall basic power and lighting symbols.  In my searching, I've found people discussing a "Power and Lighting" tool pallette, however I cannot find where I would be able to add that to my existing pallette ribbon on the side of the workspace.  Again, I am very new to AutoCAD.  This is required course material for school, and due to a missed class (unexpected), I am virtually on my own to figure out the missed material.  I really do have a strong desire to have an in-depth knowledge of AutoCAD, but this is very frustrating to not be able to find something.
imadHabash
HI,
you can start from Ctrl+3 ( ToolPalettes ) to find some Electrical symbols . also you can right click on the headlines to create a new palette if do you want . usually we don't insert symbols in the Mtext ( as i understand from you ) but we add the Mtext beside blocks or images that we insert .
Please ... keep going and ask till you find what you need .
Good luck ...
Imad Habash
Is it possible that the licensed student version of the software does not include some features or symbols?  I am continuing to come up empty handed in locating the symbols that are needed.
imadHabash
start from this AUTOCAD ELECTRICAL TOOLSET that may help . >> Click <<
Imad Habash
vinodkl
You may look into the Tool palette(Ctrl+3) for Electrical symbols. But there are very few symbols in them.
You can just do a google search and you would find plenty of results
Electrical symbols
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
en respuesta a: vinodkl
There are some basic electrical symbols included in the tool palette, which I have browsed through in its entirety.  The problem that I'm running into is the inclusion of basic symbols for power and lighting, that I feel should be included in the AutoCAD software.  In class, we have not covered downloading and installing additional libraries of symbols, so surely these are items that should already have been downloaded with the software.  This is going to be a long post, so please bear with me.  My assignment for my AutoCAD class is to complete a basic Electrical Legend, that would include the following symbols:
110/120 Volt Duplex Convenience Outlet
110/120 Volt Ground Fault Circuit Interrupt Duplex Outlet
110/120 Volt Waterproof GFCI Duplex Outlet
110/120 Volt Split Wired Outlet
220/240 Volt Outlet
Junction Box
Cable Television Outlet
Clock Outlet
Door Bell
Single Pole Switch
Three-Way Switch
Ceiling-Mounted Light
Wall-Mounted Light
Fluorescent Light
Circular Recessed Light
Square Recessed Light
Light, Fan Combination
Light, Fan, Heat Combination
Ceiling-Mounted Smoke Detector
Wall-Mounted Smoke Detector
This task is assigned from a provided list of problems within the AutoCAD 2018 Textbook, showing the appropriate symbol next to each line, however the corresponding chapter discusses nothing regarding how to add symbols, outside the use of the symbol dropdown from the text editor.  I have a licensed student version of AutoCAD 2018, 2019 and 2020, none of which include the Electrical Toolset, which the AutoCAD website claims is now included with the software.  I'm just completely lost, and it is becoming extremely frustrating.
cheryl.buck
Hi @Anonymous,
I am sorry to hear of your frustration and hope you were able to figure this out. Although I am coming in quite a while after the original post, I wanted to answer your question for any other members that encounter the same problem.
The Electrical Toolset does have a very wide variety of electrical symbols and is included in the subscription for the full version of AutoCAD. All the toolsets are separate installations that can be downloaded from your Autodesk Account
 All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
adeltaie81
motor 3 phase
CGBenner
en respuesta a: adeltaie81
@adeltaie81
Welcome, do you have a question?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
