- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> When I hit print, nothing happens
What happens if you use the command (type it into the commandline): _PLOT<ENTER>
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
to print preview. It is weird because I was able to print a couple weeks
ago.
I appreciate any help you can offer.
Nicole Ellison
720.474.9643
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
Nothing happens when I type "plot" then enter. Nothing happens when I try
ago.
Nicole Ellison
720.474.9643
If you add the underscore before "_PLOT" like Alfred suggested or a period before ".PLOT" do you get the dialog box? Can you use the PUBLISH command or does it also do nothing?
Nancy
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
print out of the publish command, which is good news.
Nicole Ellison
720.474.9643
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> Nothing happens when I add the underscore or .plot.
Hard to beleive, let's try one more step:
Start command _.PLOT using keyboard, then <ENTER>, after that press <F2> and let us know what you get then as result in the command area (screenshot may help).
>> It is weird because I was able to print a couple weeks ago.
So that sounds like there were changes done to your system. To check if the installation of AutoCAD has got defects you can login to your system with a new Windows account and see if AutoCAD can plot then or not, ... if it can plot then it might be a defect AutoCAD profile.
- alfred -
Alfred NESWADBA
