Kent1Cooper
en respuesta a: vinodkl
@vinodkl wrote:
You can also set "VIEWRES" to higher value such as 10000, which makes the circle look more smooth.
That is definitely the solution to the kinkiness of curves in the 2nd through 4th images, and would also affect the look in the 1st if that's an Arc or Circle.  Whether there's an actual intersection there to Osnap to, we can't tell from an image.
The maximum setting in VIEWRES [answer Yes to the question before it asks for a number] is 20000, and you may as well go all the way, with current computing power [the kinky display of curves was a time-saver when computers were slower].  But even without setting that, REGEN will smooth them out appropriately to the viewing zoom level at any time.
Kent Cooper, AIA
