2382 Vistas, 3 Respuestas
Can't find an intersection point on an arc line
Hello!
I am trying to make one line to attach to an arc line (see below photos). I've tried to "join" the whole object, sometimes it works but sometimes it doesn't...it is just not showing a "green X" on the point where  I want the line to be attached.
And when I stratched the line to attach to the interection point with another arc line (see below photo where the red point is). It seems like the green X doesn't detect on the right point...
It is also really weird that if I zoom into the object and it shows like this (see below first photo), so then I use "REDRAW" but still not working...it should look more like this when I zoom in...arc lines are more smoother (see below second photo). Just wondering is it because I didn't turn on any setting that it should be on?
Thank you for your big help!!!
