02-05-2020
10:43 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-05-2020
10:43 AM
Hello I have a 2 part question and according to this image. https://imgur.com/oCrr2eO Question #1, when I open a new drawing, the AutoCAD window is maximized over over the windows task bar.. it's full screen. I work in SDI 1 mode 90% of the time, multi windows. Is there a way to prevent AutoCAD from opening drawing in full screen? Question #2, I just noticed after the 2018.1.2 update that there is a change in the layout bar (mine is at the bottom and I don't remember how I took it from top to bottom unfortunately). The layout tabs are on the same line as the other options: Paper, Osnap, lock the viewport, etc, all in the same line, probably to save vertical screen space? Is there a way to separate the layout tabs from the option buttons on 2 different lines again? so they can spread along the whole length of the screen? (The layout tabs) Thanks
¡Resuelto! Ir a solución.
