484 Vistas, 1 Respuesta
AutoCAD LT 2020 reduce node on polyline
I am running AutoCAD LT 2020 and have to convert splines to polylines to output to a cutting machine.
When I convert the splines they have a large number of nodes even when I set it to zero for conversion.
Any way to reduce the number of nodes on a polyline other than deleting them one at a time?
Alfred.NESWADBA
en respuesta a: Anonymous
Less nodes means less accuracy ... and setting the precision to 0 already means your resulting geometry (if the spline is curvy) is already away from the original path.
There exist some tools for AutoCAD, but not for LT.
So I would suggest to manually recreate the path using the polyline with arcs or ask the vendor of the drawing if he can already create the paths as polylines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
