- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Inserting Blocks
I was able to insert blocks from the blocks palette just fine earlier today but now, they aren't showing up. It is like the program is ignoring the command. Only way for me to get a block in to my drawing is to Control C (copy) and Control V (paste) it in to my drawing. Not sure what system function I would alter to make that happen. How do I fix it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Those blocks don’t live in the tool palette, they live in a dwg file which plays host to the blocks. The palette’s role is to make it efficient for you to access that dwg file so you can streamline your block insertion workflow.
Has the location of the block dwg changed? Or been renamed?
The palette icon points to the location of the block drawing. Has the pointer been over written or deleted?
Chicagolooper
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
are referring to designcenter tool palette? if yes then you need to delete the existing one and create a new one. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I guess your referring to the block palette which is seen in AutoCAD 2020.
Chances are that, the palette might be off screen. Try the following method mentioned in the below link.
Palettes flicker or will not display in AutoCAD
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ultimately, I had to re-set my settings to default. It may have had something to do with a block I inserted and my program locked up which caused something to mess up my settings for inserting blocks. I think it had something to do with the "system variable monitor" message I kept getting. No matter what block I tried to insert from the palette, nothing would insert and there was nothing in the command dialog to tell me what was going on.
