Alfred.NESWADBA
en respuesta a: Anonymous
>> is about a file that includes maps (pdf)
Well, if the dwg-file itself has 70MB and you loaded additional XRefs/PDFs then I guess you are close to the limits of AutoCAD, graphic card or your system.
If the PDF's are vector files, then I would import them to dwg instead of referencing the PDF-files (referenced PDF's are really heavy for the display).
>> I attach a screenshot of a fatal error
When do you get this exception, while loading, while working, with some specific commands or only within this project?
Try to start AutoCAD and run command _RECOVERALL to see if your main DWG-file or the referenced ones contain issues.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
