01-29-2020
06:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-29-2020
06:20 AM
In that case, I apologize better to you, I sometimes have problems with the translation and interpretation. ![]()
The minimum Script content you need to test is a line with WMFOUT,
i am sure you get the name 'unknown command' message if you run the accoreconsole 2019
;;;STARTSCRIPT
WMFOUT
And if you don't use the logfile, you can start the script by using a *.bat and pause the cmd sequence to read the console window.
Ready test package attached (hardcoded path to D:\ for dwg and scr file, edit the path in *.bat file if needed)
Sebastian
