GrantsPirate
en respuesta a: Anonymous
Usually in this case the door way opening is the way to go.  Draw a line across the door opening, then using the scale command you can pick one end of the line, use the Reference option and pick both ends of the line, then enter 3'.  Measure the opening again and if it is still off then go again until you have it dialed in close enough.  Scanned drawings will not ever be exact but I guess good enough since you have no dimensions to go from.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
