01-28-2020
03:09 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-28-2020
03:09 PM
>> I just need to insert my PDFs at the correct scale to trace over
Use command _PDFATTACH to display the pdf-content inside AutoCAD.
Assuming you have a dimension in the pdf-content you can then use command _SCALE with option _REFERENCE to scale the pdf according to the 2 points dimensioned in the pdf and the real value this vector should have.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
