1556 Vistas, 6 Respuestas
3D model, lines in layout and dimension
I'm a AutoCAD beginner.
I create 3D model:
3dm3dm
Now, after that i go to Layout1 and create it view. (Layout Panel --> Create View --> Base --> From Model Space).
Below drawing are in 1:1 scale.
By using Annotation i created Dimension on model with 1:1 and with 2:1 scale - both results are equal and correct.d2.jpg
I create the red Line in layout by using Home --> Draw panel like in below image on both objects and used again Dimension.
Now lengths are different - i understand why (scales are different) but is there a way to correct or control scale/space for Dimension tool after changing object scale?
Thanks for help,
A.M.
