618 Vistas, 9 Respuestas
Autocad 2019 does not run smoothly on windows machine
Dear sir or madam,
I am a member of the I.T team of Eunice Energy Group in Greece. We use Autocad for major projects in our organization but unfortunately we face serious issues using it.
We need your assistance in order to get new infrastructure to support autocad for a descent running procedure.
At the moment we have a workstation with CPU RYZEN 5 3600, NVIDIA Quadro 3600 3Gb ram, 16Gb ram on motherboard, MSI Motherboard X570-A Pro and SSD Adata XPG SX8200 Pro.
Unfortunately, autocad does not have a proper synchronization with the mouse, while it works smoothly with any other application on it. It cracks and delays the moves. It does not crop, it does not execute basic commands such as:
  • Align
  • Xref
  • Insert images, pdfs etc
  • Crop & trim (when referring to contours, or roads etc)
  • Explode etc etc
The file size is up to 70Mbytes. Additionally to this, files such as jpegs and tables have been removed from dwg file.
Firstly do you think that the specs of our workstation are good enough to run autocad?
If not could you provide us a descent configuration of a branded machine in order to run your product smoothly without any interactions?
Best regards
