- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I use many blocks with multi-line attributes and would like a quick way to edit the mtext without opening the text editor, which is four rather time-consuming steps.
What I would like is a way to click, enter text, press enter, and see the multi-line attribute change without ever seeing the attribute editor or using the text editor.
I know this is possible because the VERY useful app "Increment" by Guilles Chanteau can increment and edit multi-line attributes, but it's not quite what I need for entering text that doesn't increment.
Let's say you have a detail title block inserted ten times and you need the blocks to be numbered 1 to 10. Increment will go through and edit the blocks instantly by just clicking on each block in succession. No text editor, no nothing, just a click and the attribute changes instantly without a regen.
¡Resuelto! Ir a solución.
