01-24-2020
08:08 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-24-2020
08:08 AM
Copying Dims - Appear huge
Hi All,
Having some issues copying dims, whereby the dims appear massive in the drawing i am copying into.
Assume it is some sort of variable i need to change but i cannot figure out what.
I am trying to copy from 'FGHJ 101' into 'FH-01'.
I would be grateful for any advice. Thanks
01-24-2020
08:58 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-24-2020
08:58 AM
It sounds like your CANNOSCALES in modelspace are set differently from one drawing to the other. Is this the case?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted
01-24-2020
09:33 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-24-2020
09:33 AM
You use annotative dimensions.
You appear to be copying annotative dims from a 1:100 scale viewport to a 1:50 scale viewport, and the dims are just not auto-resizing? They do here with your two files, but you can simply fix that b y setting ANNOAUTOSCALE to 4 in all of your DWG files (or rescale the viewport to 1:1 then bck to 1:50).
HTH
HTH
01-24-2020
09:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-24-2020
09:42 AM
Just after copying the drawing into "FH-01" select one dimension and then right click and select similar. Now open up the properties(ctrl+1) and then under the header "text" reduce "text height" to 1.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
