cadffm
en respuesta a: m_kingdon
You asked about linetypes with this question:
"can I set my Measurement to 0 without effecting anything other than the behaviour of hatch scales?"
The answer is No, because it also controle the source file for linetype definitions.
Or i understand your question not the way your words say. If you ask for hatches only: It is only for the hatch defintion, as i said the definition is the same for the standard pattern, except the distances/size of the patter.
For you the only difference is the scalefactor.
Your question about ANSI and ISO (also, it is a Question also for Linetypes :cara_guiñando_un_ojo: :cara_de_decepción:
You can use all pattern, ANSI or ISO or *whatever*,
They only thing is that the ISO definition fits good to each other ISO defintion in the question of scaling!
Sebastian
