- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
numbering automatically a text
Hello, here is my problem... I am working at a project in which there are a lot of in situ piles. I am at the moment numbering each of them, so I createad a circle and I had put a number inside of it and copied that into the following in situ piles. My problem is I have to change the number of each in situ pile manually, which requires a lot of time, so I thougth there must be a better way of doing this, and that is the reason why I am creating this thread. I am uploading a picture of a part of the insitu piles that I currently have in my project, so you have better conditions to help me.
best regards
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Something seems to be up with attachments and the forums lately.
There are a couple of methods you can use, I would recommend either creating a macro that will increment the value on insert, or finding one of the many custom lisp routines that will automatically increment numbers as you insert items.
Lee Mac has a very nice one here:
http://www.lee-mac.com/numinc.html
There are some forum posts related to your request:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-for-text-increment/td-p/7386837
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You could use TCOUNT to do the automated Sequential numbering. Refer Below links to learn more on the command
(Bonus)Also refer to TCIRCLE for adding circle to your numbers
SALMANUL FARIS![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I already used the TCount, it worked in this problem. Thanks for the help.
best regards
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You could also use this lisp(see attachment) for incremental numbering.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
