Ianhamilton
en respuesta a: Ianhamilton
OK so i found an online converter to turn the STL into a DXF file. This was able to open in autocad. I then used the CONVTOSURFACE command followed by the CONVTOSOLID command to turn it into a regular 3d solid model. And of course when i was done editing i set FACETRES to 10 and then used the STLOUT command to turn it back into and STL.
