ed57gmc
en respuesta a: bianca.tardini
@bianca.tardini wrote:
Thank you very much, this seems to have fixed it! I closed all the open drawings and then proceeded to re-open one:  the UCS was finally normal!
But how did it switch in the first place, did I type something by mistake? I do not recall clicking in the upper left corner and selecting anything!
Besides the ways Kent mentioned, you can set it from the View tab of the palette. If you don't remember, its not possible to know what you did or didn't do. All you can do is make sure that its not set in your template so that new drawings won't be affected. Start a new drawing and check the viewport to see if it is set to a visual style other than 2D wireframe.
Ed
How to post your code.
