431 Vistas, 5 Respuestas
file/drawing doesn't open completely
posting acad file for review. It is every drawing I try to open. I have sent these drawings to other people and they open correctly.
Alfred.NESWADBA
en respuesta a: Anonymous
No file attached here...
What happens every time you open a drawing?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Quick description of the problem. Got new computer so transferred ACAD LT 2017 from old computer to new computer. Drawings would not open. Tried all suggestions from the forum.
Reviewed with my IT expert. Simple fix. The graphics card accelerator was turned on on the new computer. Turned that off, problem fixed.
Remember to try the easy things first.
What is your previous version of AutoCAD?
Did you try to use Design Review  to convert your .dwg to a compatible version?
Attach an example of your .dwg for me to check.
Alfred.NESWADBA
Did the IT guy really tell you this is fixed?
The need to turn off hardware acceleration means your graphic card driver has issues.
- alfred -
Alfred NESWADBA
The autocad program highlighted the graphic card. When turned off, no issues. I have opened at least 30 files and no issues.
