- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Problem with plotting with shaded views.
Hello everyone,
I am working with AutoCAD 2020 in the area of 3D
and have problems plotting drawings with shaded views,
see attachments / pictures.
Everything is displayed correctly in the layout and in the plot preview,
but the textures are then missing in the plot itself.
I have linked search paths for textures accordingly.
Plotters and printer drivers have already been updated.
Does anyone have any idea why this is?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
can you please try the same using an AutoCAD PDF plotter.
If the same happens then again then please:
- upload the dwg-file with this layout (including the images if used any own ones for texture mapping)
- upload the PDF you get as result
- start command _ABOUT and show us a screenshot from this dialog
... so we can try this on our systems.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello Alfred,
thank you for your offer to have a look at the files.
I am happy to upload them here.
greeting
Dirk
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That is what I see when I open your PDF, textures are visible!
So for me this looks like the plot contains textures, what may I have misunderstood?
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello Alfred,
correct, if I print the drawing as a PDF, everything is taken over
correctly, then I can also print out the drawing (PDF) on the plotter
or on the printer including the textures - color representation.
But that means I always have to make the detour first,
then commit to print.
I cannot create the color-fast print directly from AutoCAD.
The preview always fits, but printing is without textures.
I also tested this at my home yesterday evening on a local printer,
but also with the result that the textures are missing when printed,
only the contour lines, i.e. visible edges, are always printed.
greeting
Dirk
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Cool (not really), I can confirm that printing to AutoCAD PDF ... shows all well, while printing to any real output device (or e.g. PDFCreator) does not show the rendered version. I would say bug (as the preview looks different to the real output). Please forward it to Autodesk.
A workaround you can use is to not use a Drawing-View object for this textured representation, instead use a normal viewport, set it's visual style to "Realistic" as shown in the attached sample.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello Alfred,
once forwarded the problem directly to Autodesk.
Let's see what comes with it.
Thank you very much.
greeting
Dirk
