01-14-2020
08:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-14-2020
08:20 AM
These are the proxy object which comes from other AutoCAD Vertical products(AutoCAD Architecture, AutoCAD Mechanical etc) and you need to export the drawing to work with plain AutoCAD.
To do that type in the command " AECTOACAD" and tap the enter the twice, which would export the drawing to be compatible with plain AutoCAD. The drawing will be saved in the same location where the main drawing is with prefix "ACAD-"
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
