- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I cannot erase some shapes in AutoCAD 2020
Hi All,
I can't seem to edit/erase some shapes in AutoCAD 2020. After pressing the erase button in the modify panel, the shapes and the enter button, nothing happens. The shape is still there. I'm not sure why.
Thanks for the help.
Kind regards,
Ian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Type in the command "PICKFIRST" and set it to "1"
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
is that means that you're able to erase others ? if yes ... you may need to check your layer status for those undeleted shapes .
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ok... what do you mean by Shapes ... is it blocks or xrefs or lines .... ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
ACAD_PROXY_ENTITY
Color Yellow ByLayer
Layer Instrument
Linetype ByBlock
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It won't let me load DelProxy.
I get an error message saying, "This file does not have an app associated with it for performing this action".
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
These are the proxy object which comes from other AutoCAD Vertical products(AutoCAD Architecture, AutoCAD Mechanical etc) and you need to export the drawing to work with plain AutoCAD.
To do that type in the command " AECTOACAD" and tap the enter the twice, which would export the drawing to be compatible with plain AutoCAD. The drawing will be saved in the same location where the main drawing is with prefix "ACAD-"
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
would you try -EXPORTTOAUTOCAD command and see if any changes ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I get an error message saying, "This file does not have an app associated with it for performing this action. Please install an app or, if one is already installed, create an association in the Default App Settings page".
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
can you please upload the dwg-file and describe which of the entities can't be removed?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'm sorry, I can't, the file is highly confidential. I can only say that when I press the shapes, I only end up with 'command:'.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
are you able to use copy & paste within this drawing with just one line?
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
please try to use command _SAVEAS and select the filetype "DXF-2000" ... close the file.
Now try
- to open the DXF ... anything better
- create a new dwg-file and use command _INSERT to insert this DXF file ... anything better?
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
