Alfred.NESWADBA
en respuesta a: Anonymous
depending on the point on the dimension items where you want to have an object snap working, please start command _OPTIONS ==> Drafting ==> uncheck "Ignore dimension extension lines" ... maybe this is already the solution.
If that does not help please ...
  • upload your drawing with just one dimension and draw a circle around the point where you can't use the object snap
  • start command _ABOUT and show us a screenshot from this dialog
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
