- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Alright, thank you Alfred. This is pretty much what I was thinking but wasn't sure. Yes all my measurements are correct and true but they were just lines along the X,Y,Z planes. So I extruded the 2D surface and now I have a solid object.
Thank you also J.Pal, I will need to remove the cylinders because essentially what I have now is solid cylinders inside the solid object I created, they are not actual holes right now. I will work on getting that portion right. Thank you for the tips.
As for the CNC program being able to translate my drawing into something it can read and cut, I have no idea at this point. My concern is being I am using R14 that the files generated might not be support. I am not overly concerned though because there are usually ways to get around these issues with older programs.
