en respuesta a: Anonymous
Hi I don't know  if anyone still needs this but I found a solution to this, just make sure that the location of the image you pasted in the dwg file wasn't removed or moved.
1.  Click the border of the missing image and go to the ribbon tab
2. Click external references and choose the image you want retrieve.
3.  Right click on that file and Reload and that should do the job!
Good luck! :cara_con_una_leve_sonrisa:
Click external references.Click external references.This shows your attached files/ images and you can hover to the file to see a preview of what it is if you're not sure which one. Then you can right click on the file and click reload, this worked for me just fine!This shows your attached files/ images and you can hover to the file to see a preview of what it is if you're not sure which one. Then you can right click on the file and click reload, this worked for me just fine!
