sthompson1021
en respuesta a: Anonymous
I was just getting ready to reply when you posted your solution. I use 2014 for everyday work but I do have 2016 on my computer. I noticed that our titleblocks were getting cut off with 2016 to and checked the margins and they were the same between 2014 and 2016. Adjusting the margins on 2016 worked but I found that using ANSI full bleed B (11x17) also worked. Just not sure why the same paper size with the same margins would give 2 different plots but 2016 dwg to pdf has other issues too from what I've been seeing on the forums. Anyway glad you got it figured out.
