315 Vistas, 2 Respuestas
Detailing an assembly in one file from a 3d mode to layout
I have an assembly of several individual 3d solids drawn in Autocad.  I can dimension one detail....on one layout.  How can I detail a second detail on layout two.  As soon as I turn layers on they show up on the layout one.  How can I only associate the detail/layer to that layout mode.
steve216586
en respuesta a: Anonymous
Don't use the global layer on/off freeze/thaw. Use the viewport freeze/thaw buttons in layer manager. Just double click in the viewport to activate it and click on the rectangular icon in layer manager pull-down to freeze layers you don't want and thaw layers you do want. This won't effect any other viewports or the model space objects.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Use command LAYFRZ in viewport it will turn off (freeze) just in this viewport (or command "_VPLAYER" "_FREEZE" nameoflayer
