jroberts92
2009 Vistas, 5 Respuestas
Some materials black, render and realistic view
Hi, I am trying to apply certain materials especially the better quality ones. However when I view them in the realistic view or render they completely black with a 'sheen' of the colour showing. I assume this is a lighting issue I want to be able to do lots of components and don't want to be changing lighting settings all the time.
Any help would be appreciated.
Dan
I am using AutoCad 2020 - Student Version
Alfred.NESWADBA
en respuesta a: jroberts92
Please upload the dwg-file with the camera view set to current which you try to render.
If it's a lightning issue and your scene does not have enough illumination available then "not changing the settings" will not bring you to your goal.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
S.Faris
Refer to this post: https://forums.autodesk.com/t5/autocad-forum/i-can-t-render-certain-materials-properly/td-p/7446377
@Alfred.NESWADBA has an accepted solution, which might work for you.
SALMANUL FARIS
jroberts92
en respuesta a: S.Faris
Thanks for this, it works when I render perfectly but when it's in realistic view it's still black? I'm not sure if this intentional or not but I do recall on much earlier versions of AutoCAD the materials seemed brighter.
If this is just an issue with newer versions then I can just do quick low quality renders I guess to get a rough idea.
Alfred.NESWADBA
Rendering has a lot of settings all influencing the result. Uploading the drawing and lettings us know which version of AutoCAD you are using will result in better suggestions and faster a valid result for you.
Just telling us "it's still black" can be everything and could be a 14 day thread full of guessing.
- alfred -
Alfred NESWADBA
S.Faris
Did you try the solution from the link? If yes, attach the output file here
SALMANUL FARIS
