TheCADnoob
en respuesta a: Anonymous
What are you trying to do once you have a connection?
Ive never called from php so im not exactly sure how to do it , but some info below may be helpful.
depending on what you are trying to do there might be tools in Forge that might help
https://forge.autodesk.com/categories/php
If you are just trying to automate something local you can see about passing something from php to the shell and using coreconsole
http://cadpanacea.com/wp/?p=655
Also if you know VBA you can use it inside CAD as well as lisp
you can also check out the ObjectARX and possibly call C form PHP
https://adndevblog.typepad.com/autocad/2013/01/understanding-objectdbx-and-realdwg.html
CADnoob
