279 Vistas, 2 Respuestas
I need to learn how to scale...
Working for the engineering department for the Kellogg's Company, I have never used AutoCAD much.
Attached is a particular example of a CAD drawing that won't sit on a full 11x17 page because I can't figure out how to scale it properly to do so when outputting the file to PDF to then print.
Could someone explain this to me. Every time I try to scale the page cuts off or is far too small
slphantom
en respuesta a: Anonymous
window what you want to print then fit to paper.
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
s.borello
If you want your drawing scaled properly, you need to use a viewport and assign a scale to it that will fit on your sheet.  If you just want to fill the page, and your not concerned with having a scaled drawing to measure off of, then you can follow the advice from @slphantom
