9460 Vistas, 18 Respuestas
Cadworx object enabler for autocad 2020
I'm looking for Cadworx object enablers for AutoCAD 2020.
I'd appreciate any help.
Thanks.
Charlie
Alfred.NESWADBA
en respuesta a: Anonymous
Please ask the developer of Cadworx, this is not an Autodesk application.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Thanks.
I'm well aware of what Cadworx is and that it is not one of AutoDesk's
applications. I was hoping I could find a user who had the Object enabler
file.
Thanks.
Charlie
pendean
if I may ask, why do you need another user to give you the plug-in and not get it yourself from Cadworx?
Or can you not find it because it doesn't exist and you are wishing for some backdoor solution?
en respuesta a: pendean
Sorry I can't find it and was hoping I was missing it.
Charlie
pendean
I assumed so: it's best if you reach out to Cadworx and see if there is a hidden one or if they even plan on releasing one at all.
All I find available is 2019 on the web: you might have to step back in AutoCAD if you need the OE in the meantime.
Thanks.
I will do that.
Charlie
pghcivil3d
@Anonymous Did you have any luck getting the CADWorx 2020 OE from them?
Rob Sinclair
Did you find it?I'm looking for this enabler too!
Etiquetas (1)
No not yet.  I don't believe it has been developed yet.
Charlie
I believe this is the object enabler you're looking for:
https://hexagonppm.com/offerings/products/cadworx-plant
This will give you CADWorx_OE_2020.zip
Thanks.
pghcivil3d
@Anonymous Thank you!
Rob Sinclair
Owackenreuther
Thank you for providing the file.
Yes I found it.  Have you found it?
Charlie
dtouchton73YH6
Thanks, I've been looking for months. Great Help much appreciated..
dtouchton73YH6
Metalman,
I ran the object enabler 2020, but its wanting service license to load. If im loading on a machine that does not have cadworx what license is it wanting? Enabler 2019 and below work fine but his new not the same. your thoughts.
Dan
pendean
en respuesta a: dtouchton73YH6
>>>...what license is it wanting?...<<<
Ask cadworx support while you wait...
ferdoX
You need to unzip folder License Files in the same location as the installation file.
