Alfred.NESWADBA
en respuesta a: Anonymous
>> I need to rotate image to 1,5 degree
just to make sure ... you are entering 1,5 or 1.5 ... as a comma is not a decimal separator in AutoCAD, you need to use a point.
Second question ... how do you verify the angle you rotated? If you use a dimension, then make sure that the dimension style is set to show more digits, not 0 as it would be the default in AutoCAD (and so the angle could be 1.5, but AutoCAD would show the value rounded to 2)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
