680 Vistas, 2 Respuestas
Rotation in autocad
Good day. In my job with objects in Autocad 2015 i have a problem. I need to rotate image to 1,5 degree or like 1 degree and 30 minutes. But when i put this information in different forms it accepts my data but turns image only to 1 or 2 degrees. So is it possible to rotate object to 1,5 degree and how? Or maybe it's possible only with integer numbers.
imadHabash
en respuesta a: Anonymous
i suggest to check from DDUNITS command your angle precision .
Imad Habash
Alfred.NESWADBA
just to make sure ... you are entering 1,5 or 1.5 ... as a comma is not a decimal separator in AutoCAD, you need to use a point.
Second question ... how do you verify the angle you rotated? If you use a dimension, then make sure that the dimension style is set to show more digits, not 0 as it would be the default in AutoCAD (and so the angle could be 1.5, but AutoCAD would show the value rounded to 2)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
