2468 Vistas, 6 Respuestas
Import EDF File Format
Hi guys. I have an 3d EDF file format but don't know how to import it into autocad
rkmcswain
en respuesta a: Anonymous
Have you seen this? And this?
en respuesta a: rkmcswain
Yes, I've seen them. But after I click on import, don't see EDF option. and there is no EDF file format in Import.
Alfred.NESWADBA
AutoCAD can't import EDF files, the second link @rkmcswain has shown was another product of Autodesk (ALIAS) that can import it, so if you have access to ALIAS it might help at least to convert the file.
Otherwise please ask the creator of the file which alternative export options he has in his software.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
rkmcswain
If you read the first link, you should have seen that AutoCAD cannot import EDF files. The second link points you to another application that does (or at least at one time it did).
@Anonymous
en respuesta a: Alfred.NESWADBA
Aha.Thank you so much
Thank you man.you helped me a lot
